Aller au contenu principal
Fujitsu Lifebook Stylistic Q584 Battery Replacement
Ce dont vous avez besoin
  1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Back Case: étape 1, image 1 de 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: étape 2, image 1 de 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: étape 3, image 1 de 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Inner Back Shield: étape 4, image 1 de 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: étape 5, image 1 de 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: étape 6, image 1 de 1
  7. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: étape 7, image 1 de 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Battery: étape 8, image 1 de 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: étape 9, image 1 de 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: étape 10, image 1 de 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: étape 11, image 1 de 1
    • Gently lift the battery from the casing.
Connor Stanton
Membre depuis le 09/21/17
613 Réputation
6 tutoriels rédigés
Équipe
Washington State, Team S1-G3, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S1-G3, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G3
5 membres
10 tutoriels rédigés
Un commentaire
I have flickering video problems after a drop, its probably video cable loose. Where is the video cable, To try reseating.
Vince - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 21
Total : 3,016
