Aller au contenu principal
Fujitsu Lifebook Stylistic Q584 Motherboard Replacement
Ce dont vous avez besoin
  1. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Back Case: étape 1, image 1 de 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 2, image 1 de 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 3, image 1 de 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Inner Back Shield: étape 4, image 1 de 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 5, image 1 de 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 6, image 1 de 1
  7. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 7, image 1 de 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Battery: étape 8, image 1 de 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 9, image 1 de 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 10, image 1 de 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 11, image 1 de 1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Motherboard: étape 12, image 1 de 1
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 13, image 1 de 1
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 14, image 1 de 1
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 15, image 1 de 1
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 16, image 1 de 3 Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 16, image 2 de 3 Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 16, image 3 de 3
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: étape 17, image 1 de 1
    • Remove the connector with an ESD-safe spudger.
3 autres ont terminé cette réparation.
Casey
Membre depuis le 03/25/19
280 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G1, Henning Spring 2019 Membre de l'équipe IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
3 membres
3 tutoriels rédigés
Un commentaire
step16, that metal clip is supposed to be lifted up, not departed away
net ho - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 27
Total : 1,406
