Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Full Solar Cooker Assembly
Ce dont vous avez besoin
  1. Full Solar Cooker Assembly, Parabolic Solar Cooker Part Inventory: étape 1, image 1 de 1
    • An inventory for all parabolic solar cooker parts follows below.
    • 6 Reflective Dish Sections
    • 1 Expansion Pipe
    • 1 Tripod Center Plate
    • 1 T-Bar
    • 3 Tripod Base Legs
    • 1 Cooker Flat
    • 1 Pipe Ring
    Demander à FixBot
  2. Full Solar Cooker Assembly: étape 2, image 1 de 1
    • The solar cooker part inventory continues below.
    • 1 Cooker Flat Stand
    • 2 Cotter Pins
    • 36 x 10mm Nut/Bolt Pairs
    • 6 Pipe Ring Brackets
    • 12 x 14mm Nut/Bolt Pairs
    • 2 Cooker Assembly Adjustment Star Knobs
    Demander à FixBot
  3. Full Solar Cooker Assembly, Assembling Parabolic Solar Cooker Tripod Base Stand: étape 3, image 1 de 2 Full Solar Cooker Assembly, Assembling Parabolic Solar Cooker Tripod Base Stand: étape 3, image 2 de 2
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
    Demander à FixBot
  4. Full Solar Cooker Assembly: étape 4, image 1 de 1
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
    Demander à FixBot
  5. Full Solar Cooker Assembly, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: étape 5, image 1 de 2 Full Solar Cooker Assembly, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: étape 5, image 2 de 2
    • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
    • It does not matter which direction the 14mm bolt is inserted from.
    Demander à FixBot
  6. Full Solar Cooker Assembly, Assembling Reflective Parabolic Dish: étape 6, image 1 de 2 Full Solar Cooker Assembly, Assembling Reflective Parabolic Dish: étape 6, image 2 de 2
    • Before you begin, be sure you have all parts and tools needed for assembly and a construction area that is at least two meters in diameter.
    • Lay two triangular sections side-by-side with pointed edges and bases adjacent to each other.
    • Since the sections are not flat, it is advisable to prop one end up on a box or similar object to give more stability during assembly.
    Demander à FixBot
  7. Full Solar Cooker Assembly: étape 7, image 1 de 1
    • Use the 10 mm nuts and bolts to attach the two plates together. First, hand thread each bolt/nut pair, then use two 10 mm wrenches secure them.
    • DO NOT install a nut and bolt in the THIRD hole from the center (pointed end of the section). This is where the Pipe Ring Bracket is attached later on.
    Demander à FixBot
  8. Full Solar Cooker Assembly: étape 8, image 1 de 3 Full Solar Cooker Assembly: étape 8, image 2 de 3 Full Solar Cooker Assembly: étape 8, image 3 de 3
    • After firmly fastening the two sections together, return to the third hole which was left empty. In addition to a nut and bolt, you will also need a pipe ring bracket.
    • Install the 10mm nut/bolt again but with the bolt passing through the single holed side of the bracket. Hand thread and use 10mm wrenches to tighten.
    • Be sure the bracket is NOT installed between the edges of the dish sections.
    • The direction the bracket faces does not matter.
    Demander à FixBot
  9. Full Solar Cooker Assembly: étape 9, image 1 de 2 Full Solar Cooker Assembly: étape 9, image 2 de 2
    • Repeat steps 2-3 until you have assembled the entire reflective dish, complete with all six sections.
    • Remember to install the pipe ring brackets in the correct place all the way around the reflective dish in the third hole from the center.
    Demander à FixBot
  10. Full Solar Cooker Assembly, Full Solar Cooker Assembly: étape 10, image 1 de 1
    • Place the assembled solar panel dish face down with the metal brackets on the top and facing up.
    • Set the pipe ring in the metal brackets circling the center of the dish.
    Demander à FixBot
  11. Full Solar Cooker Assembly: étape 11, image 1 de 2 Full Solar Cooker Assembly: étape 11, image 2 de 2
    • Insert a 14mm bolt through each six metal brackets and secure with a nut.
    • Tighten using two 14mm wrenches until secure.
    Demander à FixBot
  12. Full Solar Cooker Assembly: étape 12, image 1 de 3 Full Solar Cooker Assembly: étape 12, image 2 de 3 Full Solar Cooker Assembly: étape 12, image 3 de 3
    • Slide the cross bearer into the two holes in the support ring making sure the top of the cross sticks through the center of the solar panel dish.
    • Insert a 14mm bolt into the metal bracket on the support ring through the adjustable arm and secure with a nut.
    • Tighten with your hands.
    Demander à FixBot
  13. Full Solar Cooker Assembly: étape 13, image 1 de 2 Full Solar Cooker Assembly: étape 13, image 2 de 2
    • Insert a cotter pin through the holes at each end of the cross bearer.
    Demander à FixBot
  14. Full Solar Cooker Assembly: étape 14, image 1 de 3 Full Solar Cooker Assembly: étape 14, image 2 de 3 Full Solar Cooker Assembly: étape 14, image 3 de 3
    • Attach the top of the center plate of the tripod base stand to the cross bearer bar making sure the flat side of the tripod legs points away from the solar panel dish.
    Demander à FixBot
  15. Full Solar Cooker Assembly: étape 15, image 1 de 1
    • Stand the solar cooker upright on the tripod stand and attach the cooker ring stand to the cross bar coming through the center of the solar panel dish.
    • Screw a star knob screw into the hole in the top of the cross bar and tighten with your hand.
    Demander à FixBot
To disassemble your device, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Ashlie Reott
Membre depuis le 10/20/13
340 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-30, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
4 membres
6 tutoriels rédigés
5 commentaires de tutoriel
Thank you for these instructions. If it wasn't for these instructions, I would not have been able to put the solar cooker (as seen in the photograghs) together. The seller's manual fail to use photographs as this illustration clarifies.
Chris - Réponse Partager
Thank you very much ,mine came without the instructions so this has been so helpful
crafty mav - Réponse Partager
Hi everyone, I want to ask about the material used over the dish. whether it's concave mirror or some sheet. kindly someone clear my confusion. Thank you
Zoobia Abbasi - Réponse Partager
Hello, I brought the unit last year and I am looking or locate who and where can I purchase the hardware package, the unit that came missing 1/3 of the bolts, clips, and nuts,
I like to purchase a complete hardware package for my Full Solar cooker unit.
my email: pn91006@yahoo.com
Cell: 626-215-4038
Paul Paul - Réponse Partager
Can I order the following part that was missing from the order that came in Aug 2025?
Please let me know, I can pay for these parts from you stock or spare parts.
Paul
my email is pn91006@yahoo.com
626-215-4038
Paul Ng
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 20
30 derniers jours : 111
Total : 3,063
