Aller au contenu principal
Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7
Ce dont vous avez besoin
  1. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, Rear Case Screws: étape 1, image 1 de 2 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, Rear Case Screws: étape 1, image 2 de 2
    • Removing 10x Case screws
    • Use a PH#1 driver or bit to remove the 9, 7.5mm, M2 screws
    • Remove, 4, PH#1, 4.5mm, m2 screws.
  2. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, Removing case back.: étape 2, image 1 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, Removing case back.: étape 2, image 2 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, Removing case back.: étape 2, image 3 de 3
    • insert your jimmy tool vertically in the gap between the side a buttom pannel
    • Use a gentle twisting pressure to create a gap for a plastic opening pick or spudger
    • pry the borders of the back pannel
    • You can gently lift the bottom-most section to assist in separation
  3. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, Removing case back.: étape 3, image 1 de 1
    • remove the back case
  4. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, disconnect the battery: étape 4, image 1 de 2 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, disconnect the battery: étape 4, image 2 de 2
    • disconnect the battery before proceeding
  5. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7: étape 5, image 1 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7: étape 5, image 2 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7: étape 5, image 3 de 3
    • remove the 8 ph#1 bit screws from the battery
    • set the battery aside
  6. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, m.2 card removal: étape 6, image 1 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, m.2 card removal: étape 6, image 2 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, m.2 card removal: étape 6, image 3 de 3
    • remove 1 more ph1 screw from the m.2 braket
    • lift the bracket and card out gently
    • When reinstalling a m.2 card, insert it into the socket at a 45-degree angle, then tilt it flat with the board by gently pressing the back of the card into place.
  7. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, cmos battery disconnect: étape 7, image 1 de 1
    • this step is optional
    • removing and reinstalling the CMOS battery will cause a warning on boot however, this step can reset any firmware-related issues. simply press enter to boot past the warning message.
    • CMOS battery removal is a common trouble shooting step as it can solve many software-related failure modes.
  8. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, undo antena cables: étape 8, image 1 de 1
    • remove the black and white antenna wires from the fan shroud
  9. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, wifi card: étape 9, image 1 de 1
    • unplug the black and white antenna cables from the wifi card
    • unscrew the single ph1 screw from the m.2 wifi card
  10. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, cooler fan: étape 10, image 1 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, cooler fan: étape 10, image 2 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, cooler fan: étape 10, image 3 de 3
    • unplug the fan connector
    • unscrew 3 ph1 screws from the fan assembly
    • gently pry away the blower fan
  11. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, practice good maintenance: étape 11, image 1 de 2 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, practice good maintenance: étape 11, image 2 de 2
    • you got that sucker out clean it up real good.
  12. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, ram removal: étape 12, image 1 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, ram removal: étape 12, image 2 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7, ram removal: étape 12, image 3 de 3
    • remove the ram cover sticker
    • the next parts of this step are optional
    • remove dram
  13. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7: étape 13, image 1 de 1
    • Insert wisdom here.
  14. Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7: étape 14, image 1 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7: étape 14, image 2 de 3 Full teardown. Lenovo IdeaPad 3-15IAU7 Lenovo IdeaPad 3-15IAU7: étape 14, image 3 de 3
    • clean off the thermal paste with 99% isopropyl alcohol & a q tip
Guide written by Daniel Layman, CEO & co-owner of Advanced Device Repair, LLC
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 30
30 derniers jours : 87
Total : 320
