Introduction
When the function keys fail to register, it may be because the function key motherboard has been damaged. This guide will show you how to replace the motherboard in question.
Ce dont vous avez besoin
Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Remove 2 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
Loosen the black ribbon clamp using an iPod opening tool
Release the LCD screen by removing the ribbon from the body of the camera.
Outil utilisé dans cette étape :Tweezers$4.99
Release the black ribbon clamp attached to the back of the motherboard using an iPod opening tool to lift the clamp.
Remove the ribbon connecting the function key motherboard from the body of the camera using tweezers.
The function key motherboard has the SD card reader attached to the back. The motherboard and SD card combination should be replaced.
