Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Furbo Dog Camera Barking Sensor Assembly Replacement
Ce dont vous avez besoin
    1. Furbo Dog Camera Barking Sensor Assembly Replacement, Back Cover: étape 1, image 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement, Back Cover: étape 1, image 2 de 2
      • Remove the lid from the top of your Furbo Dog Camera.
      Demander à FixBot
      Ajouter un commentaire
    2. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 2, image 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 2, image 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 2, image 3 de 3
      • Rotate your Furbo so that the bottom faces you.
      • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
      Demander à FixBot
    3. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 3, image 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 3, image 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 3, image 3 de 3
      Outil utilisé dans cette étape :
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
      • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
      Demander à FixBot
    4. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 4, image 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 4, image 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 4, image 3 de 3
      • Rotate your Furbo so that the side is facing towards you.
      • Use an opening tool to separate the two plastic coverings.
      Demander à FixBot
    5. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 5, image 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 5, image 2 de 2
      • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
      Demander à FixBot
    1. Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: étape 6, image 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: étape 6, image 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: étape 6, image 3 de 3
      • Carefully remove the copper foiling that surrounds the camera hardware.
      Demander à FixBot
    2. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 7, image 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 7, image 2 de 2
      • Use a Phillips #000 screwdriver to remove the 2.5 mm screws at the top of the camera hardware.
      Demander à FixBot
    3. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 8, image 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 8, image 2 de 2
      • Gently pry the metal backing off of the camera hardware.
      Demander à FixBot
    4. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 9, image 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 9, image 2 de 2
      • Use a Phillips #000 screwdriver to remove the 0.4 mm screws that attach the camera to the Furbo case.
      Demander à FixBot
    5. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 10, image 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 10, image 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 10, image 3 de 3
      • Gently pry the camera off and detach it from the Furbo.
      Demander à FixBot
    6. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 11, image 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 11, image 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 11, image 3 de 3
      • Detach the wire attaching the camera hardware from the Furbo.
      Demander à FixBot
    7. Furbo Dog Camera Barking Sensor Assembly Replacement: étape 12, image 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: étape 12, image 2 de 2
      • Once removed, you may replace your camera.
      Demander à FixBot
    1. Furbo Dog Camera Barking Sensor Assembly Replacement, Barking Sensor Assembly: étape 13, image 1 de 1
      • Remove the barking sensor and replace it with a new part.
      Demander à FixBot
Sarah Teague
Membre depuis le 03/21/22
265 Réputation
3 tutoriels rédigés
Équipe
University of Alabama, Team 1-1, Bedsole Spring 2022 Membre de l'équipe University of Alabama, Team 1-1, Bedsole Spring 2022
UA-BEDSOLE-S22S1G1
3 membres
72 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 31
Total : 506
