Aller au contenu principal
G&G GR14 Airsoft Disassembly
Ce dont vous avez besoin
  1. G&G GR14 Airsoft Disassembly, G&G GR14 Airsoft Disassembly: étape 1, image 1 de 2 G&G GR14 Airsoft Disassembly, G&G GR14 Airsoft Disassembly: étape 1, image 2 de 2
    • The first step as with most AEG's is cyle the AEG on semi-auto twice to set the piston in the rest position and clear the chamber of any bb's.
    • Then Remove the battery and keep the back hatch open.
  2. G&G GR14 Airsoft Disassembly: étape 2, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 2, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 2, image 3 de 3
    • To begin the disassembly put the safety to the safe position.
    • This will allow you to pull on the back of the trigger guard as shown and hinge the the trigger guard out ward.
    • Next pull downward on the entire trigger mechanism as it will come straight out.
    • The cool part about this step is it's exactly like the real firearm and it serves the exact same function.
  3. G&G GR14 Airsoft Disassembly: étape 3, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 3, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 3, image 3 de 3
    • You can start removing the upper receiver from the body.
    • Just start pushing the receiver in a upward and forward direction as shown.
    • Make sure the wiring coming out does not get snagged on anything.
  4. G&G GR14 Airsoft Disassembly: étape 4, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 4, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 4, image 3 de 3
    • With the receiver completely out of the body you can begin separating the barrel from the rest of the receiver.
    • First remove the spring guide piece for the bolt pressing it forward and then pull it out.
  5. G&G GR14 Airsoft Disassembly: étape 5, image 1 de 2 G&G GR14 Airsoft Disassembly: étape 5, image 2 de 2
    • Now remove the 2 large 3mm hex bolts.
    • With the bolts removed you can now pull off the front barrel assembly.
  6. G&G GR14 Airsoft Disassembly: étape 6, image 1 de 1
    • With the Barrel section removed the hop-up and the inner barrel can slide right out
  7. G&G GR14 Airsoft Disassembly: étape 7, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 7, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 7, image 3 de 3
    • Now to return the focus to the main receiver section.
    • With the outer barrel off the charging handle should be easy to remove by pulling down from the top rear section as shown.
    • Now the fake bolt can be pulled forward and out of the receiver.
  8. G&G GR14 Airsoft Disassembly: étape 8, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 8, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 8, image 3 de 3
    • The next thing to do is remove the bolt catch. This will give you access to the small screw behind it which is part of the next step.
    • Punch out the the pin with either a thin punch or other appropriate tool. Once the pin is partially sticking out you can grab it with pliers.
    • Careful not to loose track of the spring behind the catch.
  9. G&G GR14 Airsoft Disassembly: étape 9, image 1 de 2 G&G GR14 Airsoft Disassembly: étape 9, image 2 de 2
    • Now begin to remove the 3 2mm screws found on either side of the receiver.
  10. G&G GR14 Airsoft Disassembly: étape 10, image 1 de 2 G&G GR14 Airsoft Disassembly: étape 10, image 2 de 2
    • With the screws removed you can now separate the gearbox from the receiver.
    • Start by prying the front section off a little bit. Then slide the gearbox slightly forward and down.
    • You might have adjust the selector as you go if it is being stubborn.
  11. G&G GR14 Airsoft Disassembly: étape 11, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 11, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 11, image 3 de 3
    • Now we break down the gearbox itself.
    • In this step all that is required is to remove the small spring with little hooks on both ends.
    • Once again this spring is also easy to loose, and as the center picture shows there also hard to see.
  12. G&G GR14 Airsoft Disassembly: étape 12, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 12, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 12, image 3 de 3
    • Now you can remove bracket of the gearbox motor.
    • This is held by 4 2mm screws on either side of the bracket.
    • With the screws removed the bracket will slide right off.
  13. G&G GR14 Airsoft Disassembly: étape 13, image 1 de 2 G&G GR14 Airsoft Disassembly: étape 13, image 2 de 2
    • Now carefully take the wiring out of the of the brackets on the side of the gearbox.
    • Loosening the wiring allow you to put the motor in a better position to be removed.
  14. G&G GR14 Airsoft Disassembly: étape 14, image 1 de 2 G&G GR14 Airsoft Disassembly: étape 14, image 2 de 2
    • Now take the motor cage and turn it to the angle shown.
    • Then gently pull the motor cage off without damaging the wiring.
    • From this point the motor will be hanging around...
  15. G&G GR14 Airsoft Disassembly: étape 15, image 1 de 2 G&G GR14 Airsoft Disassembly: étape 15, image 2 de 2
    • Now remove the large pin that goes through the front of the gearbox.
    • Then remove the the large retainer strap at the top.
  16. G&G GR14 Airsoft Disassembly: étape 16, image 1 de 2 G&G GR14 Airsoft Disassembly: étape 16, image 2 de 2
    • Now remove the 3 2mm hex screws.
    • It is always a good idea to start with the outside screws and then the center one.
  17. G&G GR14 Airsoft Disassembly: étape 17, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 17, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 17, image 3 de 3
    • Now take a thin tool to go into the back hole to prevent the spring guide fromshooting out.
    • You can begin to the pry the two halves of the gearbox apart starting at the back .
  18. G&G GR14 Airsoft Disassembly: étape 18, image 1 de 3 G&G GR14 Airsoft Disassembly: étape 18, image 2 de 3 G&G GR14 Airsoft Disassembly: étape 18, image 3 de 3
    • Once the gearbox is opened up quickly remove the main spring and spring guide so that nothing goes fly away.
    • After this point you can remove the gears. Just as in the other guide try not to misplace the shims unless you want to adjust the shimming yourself.
    • Check out the G&G AEG Shimming Guide Airsoft guide for more shimming info.
  19. G&G GR14 Airsoft Disassembly: étape 19, image 1 de 2 G&G GR14 Airsoft Disassembly: étape 19, image 2 de 2
    • This step is going to cover some of the unique parts of the G&GM-14.
    • The first part people notice is the unique Anti-reversal latch. This piece can be pulled right out. The spring that is attached is almost identical to those found in version 2/3 gearboxes and functions in the same way.
    • Next part is the selector piece. This part interacts with the selector on the gun and will make your gun go full-auto or semi-auto depending on it's position. if you flip the gearbox over you can actually see how it directly interacts with the cut-off leaver.
    • It should be left alone but just encase it does need replacement there is a screw on the out side allowing it to be removed.
    • Lastly there is the trigger switch. This piece is pressed into place and once the spring is detached from the gearbox post, the switch can be pulled out as shown.
    • Now you have completely broken down a G&G m-14.
Ligne d'arrivée
6 autres ont terminé cette réparation.
101 Tech USA
Membre depuis le 08/06/12
4 127 Réputation
17 tutoriels rédigés
Un commentaire
Thanks, it helps a lot!
Yuanliang Yu - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 86
Total : 11,319
