Introduction
This guide involves further disassembly of the clock radio and will require using several different tools and techniques, including using a soldering iron. If you need help on how to use a soldering iron, consult this iFixit guide: Comment souder et dessouder des connexions
Find the battery compartment on the bottom of the clock radio.
  • Find the battery compartment on the bottom of the clock radio.
  • Using your thumb, push the compartment cover latch toward the battery.
  • With the latch pushed in, pull the compartment cover upward to remove it..
Ajouter un commentaire
Lift the battery from the compartment.
  • Lift the battery from the compartment.
  • Pull the battery up and gently disconnect it from the battery connector.
  • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  • Gently pull the liquid crystal display (LCD) cover off.
  • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  • Using the wire cutters, carefully cut the plastic wire tie.
  • Grip the speaker.
  • Lift the speaker from the holder.
  • Locate the two 6mm screws on the PCB.
  • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws from the PCB.
  • Locate the four-position switch marked SW101. On the underside of the PCB, there will be 4 soldered pins as pointed at in the picture.
  • Apply the hot soldering iron to those four soldered pins to disconnect the four-position switch.
2 autre(s) ont terminé cette réparation.
Dominick Giguere
Membre depuis le 28/10/2014
818 Réputation
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 14
Total : 675
