Aller au contenu principal
GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement
Ce dont vous avez besoin
  1. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement, Fresh Food Fan Motor: étape 1, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement, Fresh Food Fan Motor: étape 1, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement, Fresh Food Fan Motor: étape 1, image 3 de 3
    • Place one hand at the bottom of the vegetable drawers and the other hand on top ensuring the glass shelf is secure and lift upwards.
    • Slide the drawers out one at a time; do not be afraid to lift slightly upwards in case the drawers are being obstructed.
  2. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 2, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 2, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 2, image 3 de 3
    • Place your hand at the back of the glass and slowly lift the glass shelf upwards.
    • After you lift the glass slowly slide it backwards and lift up to separate the glass from the shelf.
    • Remove the glass and tilt the drawer shelf sideways to remove.
  3. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 3, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 3, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 3, image 3 de 3
    • Locate the two screws on top of the deli drawer. The top of the deli drawer has two sections.
    • Remove the two screws using a 1/4 inch hex driver.
    • Lift the front section of the deli shelf to expose the temperature zone panel connector.
    • The screws hold down both sections. Do not attempt to lift the shelf without removing the screws.
  4. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 4, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 4, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 4, image 3 de 3
    • Locate the locking tab on the connector.
    • Using both hands, gently press on the locking tab and pull to disconnect.
    • Remove both sections of the shelf, exposing the deli drawer.
  5. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 5, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 5, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 5, image 3 de 3
    • Secure the temperature zone connector by placing it in the side panel hole.
    • Using one hand, lift the deli drawer upwards.
    • Tilt the drawer sideways and remove.
  6. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 6, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 6, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 6, image 3 de 3
    • Remove the screw visible when the slider is closed using a Phillips #1 screwdriver.
    • Move the slider out to remove the second screw.
    • Remove the screw using a 1/4-inch hex nut driver.
    • Repeat the above steps for the other side.
  7. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 7, image 1 de 2 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 7, image 2 de 2
    • Hold the front of the deli drawer panel and slide it out to remove.
    • Repeat the step to remove the other side panel.
    • Be careful with the temperature zone connector while sliding the panel out.
  8. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 8, image 1 de 2 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 8, image 2 de 2
    • Remove the four screws using a 1/4 inch hex nut driver.
  9. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 9, image 1 de 2 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 9, image 2 de 2
    • Gently pry open the fresh food fan connector cover.
    • Using a 1/4-inch hex nut driver, remove the hidden fifth screw.
    • Pull open the evaporator cover.
  10. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 10, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 10, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 10, image 3 de 3
    • Locate the locking tabs on both sides of the fresh food fan connector.
    • Gently pressing down on the locking tabs, pull back the connector to disconnect.
    • Using a spudger, gently pry out the fresh food fan.
    • Please pry out both the sides evenly to avoid damage to the rubber cover.
  11. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 11, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 11, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 11, image 3 de 3
    • While sliding out the fan, make sure to note the placement of the fan.
    • Inspect the rubber cover for damage.
    • Install the rubber cover on the new fan.
  12. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 12, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 12, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 12, image 3 de 3
    • Slide the new fan gently into the slot.
    • Run the connector wires through the wire holder.
    • Plug-in the connector to the refrigerator.
  13. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 13, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 13, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 13, image 3 de 3
    • Install the evaporator cover ensuring a tight seal.
    • Using a 1/4-inch hex nut driver, fasten all the five screws.
    • Put back the fresh food fan connector cover.
  14. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 14, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 14, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 14, image 3 de 3
    • Line up the back of the side panel with the tab located on the side of the refrigerator.
    • Ensure the temperature zone connector is secured above the side panel.
    • Fasten the screw using a 1/4-inch hex nut driver.
    • Install the sliders using a Phillips #1 screwdriver.
    • Repeat for the other side.
  15. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 15, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 15, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 15, image 3 de 3
    • Place the deli drawer and the back section of the deli shelf into the fridge.
    • Using both hands, reconnect the temperature zone connector with the front section of the shelf.
    • Fasten the two screws using a 1/4-inch hex nut driver.
  16. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 16, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 16, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 16, image 3 de 3
    • Re-install the vegetable drawer shelf without the glass by tilting it sideways and sliding it in.
    • Place the glass shelf and slide it in the vegetable drawers.
    • Perform a test to ensure the fresh food fan operation by using the ice maker and water panel on the door of the refrigerator.
    • Turn on the light, select cubed and then press water, crushed and cubed together at the same time to enter service mode.
  17. GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 17, image 1 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 17, image 2 de 3 GE Café CYE22TP2MS1 Fresh Food Fan Motor Replacement: étape 17, image 3 de 3
    • Select yes to enter service mode on the panel.
    • Press the right hand side up arrow till you reach test mode 47 and select go.
    • In order to ensure the fresh food fan is working, the RPM should be above 2300.
Ligne d'arrivée
Paiman
Membre depuis le 07/01/24
265 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-11, O'Regan Summer 2024 Membre de l'équipe York University, Team 1-11, O'Regan Summer 2024
YORK-O'REGAN-SU24S1G11
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 38
Total : 508
