Aller au contenu principal
GPU Replacement
Ce dont vous avez besoin
  1. GPU Replacement, Graphics Processing Unit: étape 1, image 1 de 1
    • Establish a clean work space.
  2. GPU Replacement: étape 2, image 1 de 3 GPU Replacement: étape 2, image 2 de 3 GPU Replacement: étape 2, image 3 de 3
    • Turn the desktop's power supply off.
    • Unplug the desktop from all power sources.
  3. GPU Replacement: étape 3, image 1 de 2 GPU Replacement: étape 3, image 2 de 2
    • Remove the screws on the side of the case.
    • Screw types may vary by desktop case.
    • These screws hold the side panel, which promotes airflow inside the desktop. Do not misplace them.
  4. GPU Replacement: étape 4, image 1 de 2 GPU Replacement: étape 4, image 2 de 2
    • Gently remove the side panel by pulling it away from the case.
  5. GPU Replacement: étape 5, image 1 de 1
    • Place the desktop horizontally, so the motherboard is facing up.
  6. GPU Replacement: étape 6, image 1 de 3 GPU Replacement: étape 6, image 2 de 3 GPU Replacement: étape 6, image 3 de 3
    • Disconnect the 8-pin PCI-E cable from the GPU.
  7. GPU Replacement: étape 7, image 1 de 2 GPU Replacement: étape 7, image 2 de 2
    • Remove the UTS 6-32 screws on the side of the desktop using a Phillips #0 or a flathead screwdriver.
    • These screws hold the GPU in place. Do not misplace them.
  8. GPU Replacement: étape 8, image 1 de 2 GPU Replacement: étape 8, image 2 de 2
    • Gently press down on the right side of the PCI-E tab until there is a click.
    • The click signifies the GPU has been released.
  9. GPU Replacement: étape 9, image 1 de 1
    • Gently pull the GPU out of the PCI-E slot.
  10. GPU Replacement: étape 10, image 1 de 3 GPU Replacement: étape 10, image 2 de 3 GPU Replacement: étape 10, image 3 de 3
    • Line up the pins of the new GPU with the empty PCI-E slot.
    • Gently push the new GPU into the PCI-E slot until the tab clicks.
  11. GPU Replacement: étape 11, image 1 de 3 GPU Replacement: étape 11, image 2 de 3 GPU Replacement: étape 11, image 3 de 3
    • Gently connect the 8-pin PCI-E cable from the power supply to the new GPU.
  12. GPU Replacement: étape 12, image 1 de 2 GPU Replacement: étape 12, image 2 de 2
    • Screw the UTS 6-32 screws which hold the GPU in place back in using a Phillips #0 screwdriver.
  13. GPU Replacement: étape 13, image 1 de 1
    • Gently place the side panel back on the case.
  14. GPU Replacement: étape 14, image 1 de 3 GPU Replacement: étape 14, image 2 de 3 GPU Replacement: étape 14, image 3 de 3
    • Screw in the side panel screws.
  15. GPU Replacement: étape 15, image 1 de 3 GPU Replacement: étape 15, image 2 de 3 GPU Replacement: étape 15, image 3 de 3
    • Plug the desktop back into a power source.
    • Turn the desktop's power supply on.
    • If the fans on the bottom of the GPU are not spinning once the desktop is on, retry this process. Or begin troubleshooting for a defective GPU.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Mason Price
Membre depuis le 10/25/22
295 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 2-16, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 2-16, Briggs Fall 2022
CSULA-BRIGGS-F22S2G16
1 membre
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 67
Total : 2,271
