Aller au contenu principal
Galaxy A71 FPC Repair
Ce dont vous avez besoin
Vidéo d'introduction
  1. Galaxy A71 FPC Repair, Connect the charger: étape 1, image 1 de 2 Galaxy A71 FPC Repair, Connect the charger: étape 1, image 2 de 2
    • Samsung Galaxy A71 does not charge.
    • Connect the charger and press the phone as per the second image.
  2. Galaxy A71 FPC Repair, Back cover removal: étape 2, image 1 de 3 Galaxy A71 FPC Repair, Back cover removal: étape 2, image 2 de 3 Galaxy A71 FPC Repair, Back cover removal: étape 2, image 3 de 3
    • Warm the device to soften the adhesive.
    • Use plastic tools and isopropyl alcohol to separate the back cover.
  3. Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: étape 3, image 1 de 3 Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: étape 3, image 2 de 3 Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: étape 3, image 3 de 3
    • Remove all silver Phillips screws.
    • Remove the SIM Tray.
    • Use a suitable plastic tool to remove the middle frame.
  4. Galaxy A71 FPC Repair: étape 4, image 1 de 2 Galaxy A71 FPC Repair: étape 4, image 2 de 2
    • Disconnect the battery.
    • Connect the charger and measure the voltage at the two end pins. It should be ~5V.
    • If not, search for the problem at the charging board or the main flex cable.
  5. Galaxy A71 FPC Repair: étape 5, image 1 de 2 Galaxy A71 FPC Repair: étape 5, image 2 de 2
    • Remove the black tape stuck around the connector.
    • Use a soldering iron, flux and tin wire to resolder the first pin of the FPC connector.
    • If the connector is broken, it's better to replace it.
10 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 308 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 536 tutoriels rédigés
Un commentaire
Good morning. My A71 screen is blinking on and off black screen. What can I do to fix it? Also when I'm attempting to type in any chat I have to press down really hard to get the letters on the screen? As my phone heats up it goes black,if I'm in a room that has AC units it remains on for a longer period of time.
KEMBA LEOUNG TAT - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 68
30 derniers jours : 354
Total : 10,427
