Aller au contenu principal
Galaxy Book3 360 13" SSD Replacement
Ce dont vous avez besoin
  1. Galaxy Book3 360 13" SSD Replacement, Remove the Screws: étape 1, image 1 de 1
    • Flip the laptop over and remove each rubber shoe
    • Use a Philips screwdriver to care fully remove each screw
  2. Galaxy Book3 360 13" SSD Replacement, Remove the Case: étape 2, image 1 de 2 Galaxy Book3 360 13" SSD Replacement, Remove the Case: étape 2, image 2 de 2
    • After removing the screws carefully pry open the case starting on the top right hinge.
    • There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
  3. Galaxy Book3 360 13" SSD Replacement, Replace the SSD: étape 3, image 1 de 1
    • Carefully remove the screw holding down the SSD.
    • Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
    • Slide in your new SSD, and follow the previous steps in reverse.
5 autres ont terminé cette réparation.
Dan
Membre depuis le 02/18/19
4 261 Réputation
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 22
7 derniers jours : 122
30 derniers jours : 524
Total : 7,313
