Introduction
To replace the SSD you will need a Pry Tool and Phillips screw driver.
Ce dont vous avez besoin
Flip the laptop over and remove each rubber shoe
Use a Philips screwdriver to care fully remove each screw
After removing the screws carefully pry open the case starting on the top right hinge.
There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
Carefully remove the screw holding down the SSD.
Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
Slide in your new SSD, and follow the previous steps in reverse.
5 autres ont terminé cette réparation.
3 commentaires
Are you sure for the second slot it is 2280 and not 2230?
How can I be sure for my NP750QFG that it's 2280 and not 2230?
Any advice?
Mine is 15.6 size and it's for the second slot, the 13" I think didn't have a second slot.
How do I know i it's for 2230 or 2280?
