Introduction
Use this guide to replace the logic board.
Pièces
Aucune pièce spécifiée.
Take the battery cover off by releasing the locking tab and hinging the cover away.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Remove the three screws on the circuit board with a Phillips #1 screw driver.
Remove the rubber button pads from their pockets.
Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
5 autre(s) ont terminé cette réparation.
