Aller au contenu principal
Game Boy Micro LCD Screen Replacement
Ce dont vous avez besoin
  1. Game Boy Micro LCD Screen Replacement, Remove the Cover: étape 1, image 1 de 2 Game Boy Micro LCD Screen Replacement, Remove the Cover: étape 1, image 2 de 2
    • Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
    • Once the screw has been loosened, lift the cover off the back of the device.
  2. Game Boy Micro LCD Screen Replacement, Faceplate: étape 2, image 1 de 2 Game Boy Micro LCD Screen Replacement, Faceplate: étape 2, image 2 de 2
    • Locate the two circular holes on the side of the Game Boy nearest to the directional pad.
  3. Game Boy Micro LCD Screen Replacement: étape 3, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 3, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 3, image 3 de 3
    • Straighten the end of a paper clip and push it into each of the circular holes.
    • You may hear a faint click afterwards.
    • Use the paper clip to lever the faceplate off from the unit.
  4. Game Boy Micro LCD Screen Replacement, Unscrew the Outer Cover: étape 4, image 1 de 2 Game Boy Micro LCD Screen Replacement, Unscrew the Outer Cover: étape 4, image 2 de 2
    • Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch.
  5. Game Boy Micro LCD Screen Replacement: étape 5, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 5, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 5, image 3 de 3
    • Remove the three Phillips #00 screws.
    • Remove the two tri-wing screws.
  6. Game Boy Micro LCD Screen Replacement: étape 6, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 6, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 6, image 3 de 3
    • Lift the back cover off of the Game Boy.
  7. Game Boy Micro LCD Screen Replacement: étape 7, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 7, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 7, image 3 de 3
    • Remove the two Phillips #00 screws from the plastic frame.
    • As you are pulling off the plastic frame, the shoulder buttons and the volume switch may fall out of the device.
    • Underneath each shoulder button is a small spring. Do not lose them.
  8. Game Boy Micro LCD Screen Replacement: étape 8, image 1 de 2 Game Boy Micro LCD Screen Replacement: étape 8, image 2 de 2
    • With a spudger, depress the small clip on the lower right corner of the plastic guard.
    • Grab the edges of the plastic frame and lift the frame off the motherboard.
  9. Game Boy Micro LCD Screen Replacement: étape 9, image 1 de 1
    • Remove the two gold Phillips #00 screws from the motherboard.
  10. Game Boy Micro LCD Screen Replacement: étape 10, image 1 de 2 Game Boy Micro LCD Screen Replacement: étape 10, image 2 de 2
    • With one hand, gently slide the top left end of the motherboard up and out of the front case.
    • With your other hand, pull out the EMI shield until the tab comes out of the front case.
    • Once the tab is pulled out from the bottom, slide the EMI shield down and out of the device.
  11. Game Boy Micro LCD Screen Replacement: étape 11, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 11, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 11, image 3 de 3
    • The entire motherboard is now accessible.
    • Take extreme care when working with the motherboard to avoid damaging the device and its components.
    • A small ribbon cable connects the start and select buttons to the motherboard. It can rip very easily, so do not pull on it.
    • Lift the motherboard and the front plastic cover assembly off of the front case.
    • Once the front case is removed, the plastic on/off switch will fall out of place.
  12. Game Boy Micro LCD Screen Replacement: étape 12, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 12, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 12, image 3 de 3
    • When you remove the motherboard from the front case, the start and select buttons may fall out.
    • If the buttons do not fall out, remove them with a pair of tweezers.
  13. Game Boy Micro LCD Screen Replacement: étape 13, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 13, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 13, image 3 de 3
    • Without the front case, you will be left with the motherboard and the plastic mount. The LCD screen is attached to the motherboard by a ribbon and can fall off the plastic mount.
    • Using metal tweezers, grab the start/select board and slide it out gently.
  14. Game Boy Micro LCD Screen Replacement: étape 14, image 1 de 2 Game Boy Micro LCD Screen Replacement: étape 14, image 2 de 2
    • Lift the entire motherboard assembly off the plastic guard.
    • Take caution not to damage any of the gold ribbon cables on the motherboard.
    • The LCD screen is the only thing connecting the motherboard and plastic guard.
  15. Game Boy Micro LCD Screen Replacement: étape 15, image 1 de 2 Game Boy Micro LCD Screen Replacement: étape 15, image 2 de 2
    • To remove the LCD screen, carefully angle it until it is diagonal to the square hole in the plastic guard and slide it out.
    • It is now possible to remove the entire motherboard assembly from the plastic guard.
  16. Game Boy Micro LCD Screen Replacement: étape 16, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 16, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 16, image 3 de 3
    • On the plastic guard, there are two rubber pads that cover the buttons. Remove them.
    • These pads rest on the motherboard and sometimes stick to it. If they do, peel them off.
    • With the rubber pads off, you may use your fingers to remove the buttons to clean or replace them.
    • When returning the buttons to the guard, they have to be put back in exactly the way they were pulled out.
  17. Game Boy Micro LCD Screen Replacement, Motherboard: étape 17, image 1 de 3 Game Boy Micro LCD Screen Replacement, Motherboard: étape 17, image 2 de 3 Game Boy Micro LCD Screen Replacement, Motherboard: étape 17, image 3 de 3
    • The LCD screen is connected to the motherboard by two ribbon cables.
    • Use a plastic spudger to disconnect the LCD's ZIF connector.
  18. Game Boy Micro LCD Screen Replacement: étape 18, image 1 de 3 Game Boy Micro LCD Screen Replacement: étape 18, image 2 de 3 Game Boy Micro LCD Screen Replacement: étape 18, image 3 de 3
    • Use the tip of the spudger to lift the small, black tab holding the thin ribbon.
    • With both tabs lifted, pull the ribbons off the motherboard and remove the LCD screen.
  19. Game Boy Micro LCD Screen Replacement, LCD Screen: étape 19, image 1 de 2 Game Boy Micro LCD Screen Replacement, LCD Screen: étape 19, image 2 de 2
    • The LCD can now be cleaned or replaced.
7 autres ont terminé cette réparation.
Brendan Kelly
Membre depuis le 01/26/10
269 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-46, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 8-46, Regan Winter 2010
CPSU-REGAN-W10S8G46
5 membres
25 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 39
30 derniers jours : 189
Total : 24,769
