Aller au contenu principal
Game Boy Pocket LCD Screen Replacement
Ce dont vous avez besoin
  1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: étape 1, image 1 de 3 Game Boy Pocket LCD Screen Replacement, Remove the external screws: étape 1, image 2 de 3 Game Boy Pocket LCD Screen Replacement, Remove the external screws: étape 1, image 3 de 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Remove batteries from battery compartment.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket LCD Screen Replacement, Open the device: étape 2, image 1 de 3 Game Boy Pocket LCD Screen Replacement, Open the device: étape 2, image 2 de 3 Game Boy Pocket LCD Screen Replacement, Open the device: étape 2, image 3 de 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: étape 3, image 1 de 1
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: étape 4, image 1 de 3 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: étape 4, image 2 de 3 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: étape 4, image 3 de 3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: étape 5, image 1 de 2 Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: étape 5, image 2 de 2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: étape 6, image 1 de 3 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: étape 6, image 2 de 3 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: étape 6, image 3 de 3
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: étape 7, image 1 de 3 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: étape 7, image 2 de 3 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: étape 7, image 3 de 3
    • Use a plastic opening tool to lift the LCD screen away from the front cover.
    • Use your fingers to remove the LCD screen.
19 autres ont terminé cette réparation.
Adriana Rahrig
Membre depuis le 10/07/14
1 637 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 membres
19 tutoriels rédigés
3 commentaires de tutoriel
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - Réponse
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser -
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 67
30 derniers jours : 364
Total : 31,373
