Aller au contenu principal
GameSir T4 Pro Action Buttons Replacement
Ce dont vous avez besoin
  1. GameSir T4 Pro Action Buttons Replacement, Battery: étape 1, image 1 de 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Action Buttons Replacement: étape 2, image 1 de 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Action Buttons Replacement: étape 3, image 1 de 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Action Buttons Replacement: étape 4, image 1 de 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Action Buttons Replacement, Action Buttons: étape 5, image 1 de 2 GameSir T4 Pro Action Buttons Replacement, Action Buttons: étape 5, image 2 de 2
    • Remove the three 5mm screws on the motherboard.
  6. GameSir T4 Pro Action Buttons Replacement: étape 6, image 1 de 1
    • Disconnect all white connectors from the motherboard.
  7. GameSir T4 Pro Action Buttons Replacement: étape 7, image 1 de 1
    • Carefully pull the motherboard away to reveal the front panel.
  8. GameSir T4 Pro Action Buttons Replacement: étape 8, image 1 de 2 GameSir T4 Pro Action Buttons Replacement: étape 8, image 2 de 2
    • Remove the white rubber panel to get access to the buttons.
    • Put a small dab of isopropyl alcohol on a cotton swab, and clean around the area of your sticky button.
3 autres ont terminé cette réparation.
Madison Puckett
Membre depuis le 09/16/22
755 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 36
30 derniers jours : 156
Total : 2,628
