Introduction
This guide goes over how to replace the bumpers, otherwise known as shoulder buttons, on a GameSirT4 Pro controller. If your shoulder buttons are getting stuck, cracked, or unresponsive this guide shows how to remove and replace the shoulder buttons.
Ce dont vous avez besoin
Remove the following screws on the back case using a Phillips screwdriver:
Two 9.2 mm
Two 11.3 mm
Insert an opening tool in the seam between the front and back case.
Pry around the perimeter until the back case releases.
