Aller au contenu principal
GameSir T4 Pro Joystick Replacement
Ce dont vous avez besoin
  1. GameSir T4 Pro Joystick Replacement, Battery: étape 1, image 1 de 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Joystick Replacement: étape 2, image 1 de 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Joystick Replacement: étape 3, image 1 de 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Joystick Replacement: étape 4, image 1 de 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Joystick Replacement, Joystick: étape 5, image 1 de 2 GameSir T4 Pro Joystick Replacement, Joystick: étape 5, image 2 de 2
    • Disconnect the rumblers from the motherboard
    • Be careful not to pull the wires while disconnecting rumbler
  6. GameSir T4 Pro Joystick Replacement: étape 6, image 1 de 1
    • Using the screwdriver, remove the 5 mm screws from the motherboard
  7. GameSir T4 Pro Joystick Replacement: étape 7, image 1 de 2 GameSir T4 Pro Joystick Replacement: étape 7, image 2 de 2
    • Using the wedge tool, pop the joystick out
  8. GameSir T4 Pro Joystick Replacement: étape 8, image 1 de 2 GameSir T4 Pro Joystick Replacement: étape 8, image 2 de 2
    • Make sure the square of the joystick matches the square of the pad and pop it in place.
Madison Puckett
Membre depuis le 09/16/22
779 Réputation
5 tutoriels rédigés
Équipe
3 commentaires
I bought ps4 joysticks for the repair, but ps4 joysticks seems larger so it's stuck
Mohamed NACERI - Réponse
PlayStation4 stick is not compatible with GameSir T4 Pro. The stick for the Nintendo Switch PRO controller does not interfere, but this also requires processing for installation.
NAKIRI - Réponse
It appears that you will need to remove the light diffuser(white tubular plastic sleeve) from the case to make the parts fit.
NAKIRI -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 34
30 derniers jours : 184
Total : 4,299
