Introduction
This guide goes over how to replace the motherboard on a GameSirT4 Pro controller. If your controller is having major problems with multiple components, replacing the motherboard may solve the problem.
Ce dont vous avez besoin
Remove the following screws on the back case using a Phillips screwdriver:
Two 9.2 mm
Two 11.3 mm
Insert an opening tool in the seam between the front and back case.
Pry around the perimeter until the back case releases.
