Introduction
Be very careful when handling connector wires, as they are incredibly easily broken. This guide is unique only in removing the circuit board from the screen.
Pièces
Aucune pièce nécessaire.
Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
  • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
Ajouter un commentaire
Remove the back cover carefully.
  • Remove the back cover carefully.
  • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
  • Remove the orange gasket.
  • Remove the screen and motherboard assembly from the case.
  • Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
  • Remove the screen from the golden metal clip.
  • Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
  • Remove the connector from the motherboard by pulling it free at the base.
  • Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
  • Remove the screen from the motherboard.
  • Notice our tape retaining the connector to the screen. This is so easy to rip!
  • Remove the motherboard from the screen.
Evan Miller
Membre depuis le 21/03/2018
205 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S4-G1, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 46
