Aller au contenu principal
Garmin Dash Cam 20 Battery Replacement
Ce dont vous avez besoin
  1. Garmin Dash Cam 20 Battery Replacement, Internal Assembly: étape 1, image 1 de 2 Garmin Dash Cam 20 Battery Replacement, Internal Assembly: étape 1, image 2 de 2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Battery Replacement: étape 2, image 1 de 2 Garmin Dash Cam 20 Battery Replacement: étape 2, image 2 de 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Battery Replacement: étape 3, image 1 de 2 Garmin Dash Cam 20 Battery Replacement: étape 3, image 2 de 2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Battery Replacement: étape 4, image 1 de 2 Garmin Dash Cam 20 Battery Replacement: étape 4, image 2 de 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Battery Replacement: étape 5, image 1 de 3 Garmin Dash Cam 20 Battery Replacement: étape 5, image 2 de 3 Garmin Dash Cam 20 Battery Replacement: étape 5, image 3 de 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Battery Replacement: étape 6, image 1 de 3 Garmin Dash Cam 20 Battery Replacement: étape 6, image 2 de 3 Garmin Dash Cam 20 Battery Replacement: étape 6, image 3 de 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Battery Replacement, Battery: étape 7, image 1 de 3 Garmin Dash Cam 20 Battery Replacement, Battery: étape 7, image 2 de 3 Garmin Dash Cam 20 Battery Replacement, Battery: étape 7, image 3 de 3
    • Remove the green tape overlying the pin connector with tweezers.
    • Remove the pin connector using tweezers.
    • Do not break black cord connection between motherboard and metal mount (orange circle).
  8. Garmin Dash Cam 20 Battery Replacement: étape 8, image 1 de 3 Garmin Dash Cam 20 Battery Replacement: étape 8, image 2 de 3 Garmin Dash Cam 20 Battery Replacement: étape 8, image 3 de 3
    • This step shows the use of an incorrect tool. Only use ESD safe tools when handling the battery.
    • With the the nylon spudger, lift the battery to expose and stretch the glue. Cut the glue residue by gliding the tool from left to right.
3 autres ont terminé cette réparation.
Jesse Hillman
Membre depuis le 10/04/16
757 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 2-1, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 membres
5 tutoriels rédigés
3 commentaires
An excellent article except for one major problem but, why does iFixIt not sell theses batteries or direct you on where a person could actually buy one? This knowledge is pretty much useless with out a replacement battery to actually use.
Bradley Hyman - Réponse
Yeah I agree
Yousef Ghalib -
Thanks for this guide. This gave my Garmin 20 another couple of years! :)
BTW, I was able to buy the battery replacement from Amazon: https://www.amazon.com/gp/product/B07KSR...
pro cabales - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 39
Total : 3,819
