Aller au contenu principal
Garmin Dash Cam 20 Motherboard Replacement
Ce dont vous avez besoin
  1. Garmin Dash Cam 20 Motherboard Replacement, Internal Assembly: étape 1, image 1 de 2 Garmin Dash Cam 20 Motherboard Replacement, Internal Assembly: étape 1, image 2 de 2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Motherboard Replacement: étape 2, image 1 de 2 Garmin Dash Cam 20 Motherboard Replacement: étape 2, image 2 de 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Motherboard Replacement: étape 3, image 1 de 2 Garmin Dash Cam 20 Motherboard Replacement: étape 3, image 2 de 2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Motherboard Replacement: étape 4, image 1 de 2 Garmin Dash Cam 20 Motherboard Replacement: étape 4, image 2 de 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Motherboard Replacement: étape 5, image 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 5, image 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 5, image 3 de 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Motherboard Replacement: étape 6, image 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 6, image 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 6, image 3 de 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Motherboard Replacement, Motherboard Components: étape 7, image 1 de 2 Garmin Dash Cam 20 Motherboard Replacement, Motherboard Components: étape 7, image 2 de 2
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
  8. Garmin Dash Cam 20 Motherboard Replacement: étape 8, image 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 8, image 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 8, image 3 de 3
    • Remove the metal case off of the motherboard.
  9. Garmin Dash Cam 20 Motherboard Replacement: étape 9, image 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 9, image 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 9, image 3 de 3
    • Remove the battery connection.
  10. Garmin Dash Cam 20 Motherboard Replacement: étape 10, image 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 10, image 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 10, image 3 de 3
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
  11. Garmin Dash Cam 20 Motherboard Replacement: étape 11, image 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 11, image 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 11, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to remove the connector on the top right of the motherboard.
  12. Garmin Dash Cam 20 Motherboard Replacement: étape 12, image 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 12, image 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: étape 12, image 3 de 3
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
  13. Garmin Dash Cam 20 Motherboard Replacement: étape 13, image 1 de 1
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
Jesse Hillman
Membre depuis le 10/04/16
757 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 2-1, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 membres
5 tutoriels rédigés
Un commentaire
hello Im looking for a replacement part for this Dash Cam, the socket piece. Do you have any of them?
rdlr2112@gmail.com
rushfanbytor - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 833
