Aller au contenu principal
Garmin Dash Cam 20 Screen Replacement
Ce dont vous avez besoin
  1. Garmin Dash Cam 20 Screen Replacement, Internal Assembly: étape 1, image 1 de 2 Garmin Dash Cam 20 Screen Replacement, Internal Assembly: étape 1, image 2 de 2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Screen Replacement: étape 2, image 1 de 2 Garmin Dash Cam 20 Screen Replacement: étape 2, image 2 de 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Screen Replacement: étape 3, image 1 de 2 Garmin Dash Cam 20 Screen Replacement: étape 3, image 2 de 2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Screen Replacement: étape 4, image 1 de 2 Garmin Dash Cam 20 Screen Replacement: étape 4, image 2 de 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Screen Replacement: étape 5, image 1 de 3 Garmin Dash Cam 20 Screen Replacement: étape 5, image 2 de 3 Garmin Dash Cam 20 Screen Replacement: étape 5, image 3 de 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Screen Replacement: étape 6, image 1 de 3 Garmin Dash Cam 20 Screen Replacement: étape 6, image 2 de 3 Garmin Dash Cam 20 Screen Replacement: étape 6, image 3 de 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Screen Replacement, Screen: étape 7, image 1 de 3 Garmin Dash Cam 20 Screen Replacement, Screen: étape 7, image 2 de 3 Garmin Dash Cam 20 Screen Replacement, Screen: étape 7, image 3 de 3
    • Use the Phillips screwdriver to remove the four 5mm screws.
  8. Garmin Dash Cam 20 Screen Replacement: étape 8, image 1 de 2 Garmin Dash Cam 20 Screen Replacement: étape 8, image 2 de 2
    • Use the metal spudger to remove metal plate from device. This will reveal the screen.
  9. Garmin Dash Cam 20 Screen Replacement: étape 9, image 1 de 3 Garmin Dash Cam 20 Screen Replacement: étape 9, image 2 de 3 Garmin Dash Cam 20 Screen Replacement: étape 9, image 3 de 3
    • Use the metal spudger to remove screen from device.
  10. Garmin Dash Cam 20 Screen Replacement: étape 10, image 1 de 1
    • The screen is now detached.
Jesse Hillman
Membre depuis le 10/04/16
757 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 2-1, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 470
