Aller au contenu principal
Garmin Dezl 760LMT Motherboard Replacement
Ce dont vous avez besoin
  1. Garmin Dezl 760LMT Motherboard Replacement, Back Panel: étape 1, image 1 de 2 Garmin Dezl 760LMT Motherboard Replacement, Back Panel: étape 1, image 2 de 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Motherboard Replacement: étape 2, image 1 de 3 Garmin Dezl 760LMT Motherboard Replacement: étape 2, image 2 de 3 Garmin Dezl 760LMT Motherboard Replacement: étape 2, image 3 de 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Motherboard Replacement: étape 3, image 1 de 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: étape 4, image 1 de 2 Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: étape 4, image 2 de 2
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Motherboard Replacement: étape 5, image 1 de 2 Garmin Dezl 760LMT Motherboard Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Motherboard Replacement, Motherboard: étape 6, image 1 de 2 Garmin Dezl 760LMT Motherboard Replacement, Motherboard: étape 6, image 2 de 2
    • Using a Torx T5 screwdriver, unscrew the six 5mm screws on the motherboard.
  7. Garmin Dezl 760LMT Motherboard Replacement: étape 7, image 1 de 3 Garmin Dezl 760LMT Motherboard Replacement: étape 7, image 2 de 3 Garmin Dezl 760LMT Motherboard Replacement: étape 7, image 3 de 3
    • Grasp each of the three wires near where it is attached to the motherboard. Lift them upward to detach them.
    • Lift the motherboard from the device.
Ryan Williams
Membre depuis le 09/28/16
763 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 4-2, Passmore Fall 2016 Membre de l'équipe USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 membres
6 tutoriels rédigés
2 commentaires
i realy appreciate the video but please tell me where can i find buy the motherboard or others parts for my gps rv-760
Thank you
Pierre Delisle
Québec
Canada
Pierre Delisle - Réponse
Is it possible to buy the ribbon cable from the screen to the mother board, and what’s the procedure to replace it on the display ? Thanks
Kiki B - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 2,879
