Aller au contenu principal
Garmin Dezl 760LMT Screen Replacement
Ce dont vous avez besoin
  1. Garmin Dezl 760LMT Screen Replacement, Back Panel: étape 1, image 1 de 2 Garmin Dezl 760LMT Screen Replacement, Back Panel: étape 1, image 2 de 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Screen Replacement: étape 2, image 1 de 3 Garmin Dezl 760LMT Screen Replacement: étape 2, image 2 de 3 Garmin Dezl 760LMT Screen Replacement: étape 2, image 3 de 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Screen Replacement: étape 3, image 1 de 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: étape 4, image 1 de 2 Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: étape 4, image 2 de 2
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Screen Replacement: étape 5, image 1 de 2 Garmin Dezl 760LMT Screen Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Screen Replacement, Screen: étape 6, image 1 de 2 Garmin Dezl 760LMT Screen Replacement, Screen: étape 6, image 2 de 2
    • Using a Torx T5 screwdriver, unscrew the four 7mm screws from the back plate of the screen.
  7. Garmin Dezl 760LMT Screen Replacement: étape 7, image 1 de 3 Garmin Dezl 760LMT Screen Replacement: étape 7, image 2 de 3 Garmin Dezl 760LMT Screen Replacement: étape 7, image 3 de 3
    • Turn the screen over so that it is facing upwards.
    • Remove the front plate of the screen.
    • Lift the screen from its back casing.
Ryan Williams
Membre depuis le 09/28/16
763 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 4-2, Passmore Fall 2016 Membre de l'équipe USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 membres
6 tutoriels rédigés
2 commentaires
where can one by the replacement screen
tempestrogue - Réponse
Ebay sells these screens replacement - search online for “ZD070NA-03K “ or on google, even amazon sometimes has them. Its a hard to find screen so you will probably only get it from hong kong or china.
neilneves - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 18
Total : 2,356
