Aller au contenu principal
Garmin Dezl 760LMT Speaker Replacement
Ce dont vous avez besoin
  1. Garmin Dezl 760LMT Speaker Replacement, Back Panel: étape 1, image 1 de 2 Garmin Dezl 760LMT Speaker Replacement, Back Panel: étape 1, image 2 de 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Speaker Replacement: étape 2, image 1 de 3 Garmin Dezl 760LMT Speaker Replacement: étape 2, image 2 de 3 Garmin Dezl 760LMT Speaker Replacement: étape 2, image 3 de 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Speaker Replacement: étape 3, image 1 de 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Speaker Replacement, Speaker: étape 4, image 1 de 2 Garmin Dezl 760LMT Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Using the sharp end of the metal probe, scrape away the wax around the base of the speaker.
    • Slide the metal probe underneath the speaker and pry upwards.
    • During reassembly, use electrical tape to hold the speaker into place.
  5. Garmin Dezl 760LMT Speaker Replacement: étape 5, image 1 de 2 Garmin Dezl 760LMT Speaker Replacement: étape 5, image 2 de 2
    • Grasp the speaker wire near the motherboard and lift upward to detach the connector.
Ryan Williams
Membre depuis le 09/28/16
763 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 4-2, Passmore Fall 2016 Membre de l'équipe USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 536
