Aller au contenu principal
Garmin Dezl 770LMT Screen Replacement
Ce dont vous avez besoin
  1. Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: étape 1, image 1 de 2 Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: étape 1, image 2 de 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Screen Replacement: étape 2, image 1 de 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Screen Replacement: étape 3, image 1 de 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Screen Replacement, Screen: étape 4, image 1 de 2 Garmin Dezl 770LMT Screen Replacement, Screen: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • After you've removed the back cover, you will see a copper colored ribbon connected to a grey hinge.
    • Carefully remove the hinge from the cord using a spudger and the ribbon will come out.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    • Make sure to wear an anti-static wrist strap when handling the motherboard.
  5. Garmin Dezl 770LMT Screen Replacement: étape 5, image 1 de 3 Garmin Dezl 770LMT Screen Replacement: étape 5, image 2 de 3 Garmin Dezl 770LMT Screen Replacement: étape 5, image 3 de 3
    • Now you have the screen, which is enclosed by another cover. Remove the eight screws that hold it in place.
  6. Garmin Dezl 770LMT Screen Replacement: étape 6, image 1 de 1
    • Once the screws have been taken out, use a spudger to carefully remove the cover. With this cover removed, the screen is now completely exposed.
3 autres ont terminé cette réparation.
Aleem Waris
Membre depuis le 10/10/16
146 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-3, Lacy Fall 2016 Membre de l'équipe USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 21
Total : 2,896
