Aller au contenu principal
Garmin Dezl 770LMT Speaker Replacement
Ce dont vous avez besoin
  1. Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: étape 1, image 1 de 2 Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: étape 1, image 2 de 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Speaker Replacement: étape 2, image 1 de 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Speaker Replacement: étape 3, image 1 de 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Speaker Replacement, Speaker: étape 4, image 1 de 2 Garmin Dezl 770LMT Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Using the sharp side of the spudger, scrape away the adhesive surrounding the speaker.
    • Slide the spudger beneath the speaker and pull it away from the case.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Garmin Dezl 770LMT Speaker Replacement: étape 5, image 1 de 2 Garmin Dezl 770LMT Speaker Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Grasp the wire connecting the motherboard and pull the wares connecting it.
    • Remember to wear an anti-static wrist strap when handling the motherboard.
Francisco Rosado
Membre depuis le 10/05/16
370 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Lacy Fall 2016 Membre de l'équipe USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 membres
5 tutoriels rédigés
2 commentaires
do u know where i can get a replacement speaker
markrushforth65 - Réponse
Hi where can I buy the speaker, i hardly use my deal 770 lm and speaker gave up.
Noel Borg - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 994
