Aller au contenu principal
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
Ce dont vous avez besoin
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: étape 1, image 1 de 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: étape 1, image 2 de 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: étape 2, image 1 de 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: étape 2, image 2 de 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: étape 3, image 1 de 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: étape 3, image 2 de 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: étape 3, image 3 de 3
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
4 autres ont terminé cette réparation.
Taylor McNees
Membre depuis le 10/03/19
558 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 1,567
