Aller au contenu principal
Garmin Fenix 2 Motherboard Replacement
Ce dont vous avez besoin
  1. Garmin Fenix 2 Motherboard Replacement, Battery: étape 1, image 1 de 3 Garmin Fenix 2 Motherboard Replacement, Battery: étape 1, image 2 de 3 Garmin Fenix 2 Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  2. Garmin Fenix 2 Motherboard Replacement: étape 2, image 1 de 2 Garmin Fenix 2 Motherboard Replacement: étape 2, image 2 de 2
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  3. Garmin Fenix 2 Motherboard Replacement: étape 3, image 1 de 2 Garmin Fenix 2 Motherboard Replacement: étape 3, image 2 de 2
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
  4. Garmin Fenix 2 Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • Use a spudger to pry open the power ribbon from the main board.
  5. Garmin Fenix 2 Motherboard Replacement: étape 5, image 1 de 1
    • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
  6. Garmin Fenix 2 Motherboard Replacement: étape 6, image 1 de 1
    • Use the spudger to pry the motherboard out of the housing.
  7. Garmin Fenix 2 Motherboard Replacement: étape 7, image 1 de 1
    • Once removed simply separate the digitizer from the main board.
  8. Garmin Fenix 2 Motherboard Replacement: étape 8, image 1 de 2 Garmin Fenix 2 Motherboard Replacement: étape 8, image 2 de 2
    • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
5 autres ont terminé cette réparation.
Brandon Barger
Membre depuis le 02/13/16
1 219 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team 54-4, Wilson Spring 2016 Membre de l'équipe IUPUI, Team 54-4, Wilson Spring 2016
IUPUI-WILSON-S16S54G4
3 membres
6 tutoriels rédigés
2 commentaires
Ottima, le prime guide che trovo per Garmin Fenix 2. Io metterei una foto con le specifiche della batteria. Saluti.
Ciro Filomeno - Réponse
Hi there, any idea where I can buy motherboard replacement for my Fenix 1?
hasmanizam - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 4,450
