Aller au contenu principal
Garmin Fenix 3 GPS Antenna Replacement
Ce dont vous avez besoin
  1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: étape 1, image 1 de 2 Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: étape 1, image 2 de 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 GPS Antenna Replacement: étape 2, image 1 de 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 GPS Antenna Replacement: étape 3, image 1 de 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 GPS Antenna Replacement: étape 4, image 1 de 1
    • Set the watch face aside.
  5. Garmin Fenix 3 GPS Antenna Replacement, GPS Antenna: étape 5, image 1 de 1
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 GPS Antenna Replacement: étape 6, image 1 de 1
    • Carefully remove the antenna, and set it aside.
Adam Estabrook
Membre depuis le 09/07/18
1 057 Réputation
5 tutoriels rédigés
8 commentaires
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Nico Baumgartner - Réponse
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
dusan.kosobud - Réponse
Hi did you find gps antenna
Abdessamad Faroque - Réponse
Could you please add a link where to buy the antenna?
marco475 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 62
Total : 5,295
