Aller au contenu principal
Garmin Fenix 3 HR Battery Replacement
Ce dont vous avez besoin
  1. Garmin Fenix 3 HR Battery Replacement, Battery: étape 1, image 1 de 2 Garmin Fenix 3 HR Battery Replacement, Battery: étape 1, image 2 de 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Battery Replacement: étape 2, image 1 de 3 Garmin Fenix 3 HR Battery Replacement: étape 2, image 2 de 3 Garmin Fenix 3 HR Battery Replacement: étape 2, image 3 de 3
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Battery Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Battery Replacement: étape 4, image 1 de 2 Garmin Fenix 3 HR Battery Replacement: étape 4, image 2 de 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
  5. Garmin Fenix 3 HR Battery Replacement: étape 5, image 1 de 1
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Battery Replacement: étape 6, image 1 de 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Battery Replacement: étape 7, image 1 de 1
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  8. Garmin Fenix 3 HR Battery Replacement: étape 8, image 1 de 1
    • Now attach the new battery with adhesive and reassemble.
40 autres ont terminé cette réparation.
Victor Tanguy
Membre depuis le 03/26/18
1 329 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G6, Harley Spring 2018 Membre de l'équipe IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 membres
5 tutoriels rédigés
29 commentaires
Does anybody do It in a fenix 5?
Fernando Alcaraz - Réponse
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - Réponse
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 90
30 derniers jours : 310
Total : 70,693
