Introduction
Even the best electronics die out over time, especially devices used in harsh conditions. This guide will show how to replace the motherboard of your Garmin Fenix 3 if the electronics are showing signs of failure. You will need a T6 Torx screwdriver, a T5 Torx screwdriver, and a spudger.
Ce dont vous avez besoin
Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
Outil utilisé dans cette étape :Tweezers$4.99
Locate the two silver 1.4 mm T5 screws, and carefully unscrew them.
6 autres ont terminé cette réparation.
16 commentaires
Hello,
i’m looking for replacement of start/stop button micro switch. Do you know what is the switch number which i can look for?
Thank you
that's my problem too and i can't find any solution.
Where can I find a replacement Motherboard ? None of my buttons are responding and I can’t even do a Factory reset.
All that works is switching off and back on.
I have exact same issue. I sent my watch to official repair service to Split (Croatia) and they said they aren’t able to fix it. I can see only main screen of the watch, buttons don’t respond at all. Would like to know how to fix the issue.
