Aller au contenu principal
Garmin Forerunner 25 Screen Replacement
Ce dont vous avez besoin
  1. Garmin Forerunner 25 Screen Replacement, Battery: étape 1, image 1 de 1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Screen Replacement: étape 2, image 1 de 1
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Screen Replacement, Motherboard: étape 3, image 1 de 1
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Screen Replacement: étape 4, image 1 de 1
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Screen Replacement: étape 5, image 1 de 1
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
  6. Garmin Forerunner 25 Screen Replacement, Screen: étape 6, image 1 de 1
    • Remove gold piece in the corner using the pointed side of the 4 spudger.
    • Any spudger with a pointed end should work to remove this piece.
  7. Garmin Forerunner 25 Screen Replacement: étape 7, image 1 de 1
    • Pry the screen up with a plastic opening tool.
    • Any plastic tool with a flat edge should work to remove the screen.
    • Remove the screen.
Suzanne Drumm
Membre depuis le 03/21/18
85 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S5-G3, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 11
Total : 1,679
