Aller au contenu principal
Garmin GPSmap 60CSx Gasket Replacement
Ce dont vous avez besoin
  1. Garmin GPSmap 60CSx Gasket Replacement, Back Cover and AA Batteries: étape 1, image 1 de 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Gasket Replacement: étape 2, image 1 de 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Gasket Replacement: étape 3, image 1 de 2 Garmin GPSmap 60CSx Gasket Replacement: étape 3, image 2 de 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Gasket Replacement, Gasket: étape 4, image 1 de 2 Garmin GPSmap 60CSx Gasket Replacement, Gasket: étape 4, image 2 de 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Separate the back panel from the front.
  5. Garmin GPSmap 60CSx Gasket Replacement: étape 5, image 1 de 2 Garmin GPSmap 60CSx Gasket Replacement: étape 5, image 2 de 2
    • Remove the gasket.
    • Be careful to make sure the gasket is aligned correctly to ensure it is water proof.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 23
Total : 1,639
