Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
In this guide the repairer replaces the battery of the device by disassembling it to expose the motherboard, which in turn allows access to the battery.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • Fine Point Tweezers
  • Spudger
Estimated Duration: 10 minutes
Pièces
Aucune pièce spécifiée.
  1. After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. The motherboard will now freely separate from the back casing; lay it flat next to the housing. The motherboard will now freely separate from the back casing; lay it flat next to the housing.
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Disconnect the speaker and battery from their terminals on the motherboard.  This should disconnect the motherboard completely from the back panel. It is recommended that you use tweezers or the spudger for precision.
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • It is recommended that you use tweezers or the spudger for precision.
  5. Using the flat edge of the spudger from above, gently pry the battery away from the plastic. Using the flat edge of the spudger from above, gently pry the battery away from the plastic.
    • Using the flat edge of the spudger from above, gently pry the battery away from the plastic.
  6. The battery should now be completely separated from the other components.
    • The battery should now be completely separated from the other components.
    • Insert new, functional battery.
2 autre(s) ont terminé cette réparation.
poopspeedstream
Membre depuis le 19/04/2013
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-65, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 13
Total : 1,576
