Introduction
In this guide the repairer replaces the LCD display of the device by carefully prying apart the components with one's hands.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
- None
Estimated Duration: 5 minutes
Ce dont vous avez besoin
Unscrew the two screws on the antenna unit using a torc-head screwdriver.
Gently pry open the antenna unit with your fingers.
Slide out the inner casing attached to the antenna body.
Remove the rotating joint connecting the antenna casing to the main device:
Squeeze tweezers into the shown location and compress the spring.
Lift out the outer casing while keeping the spring compressed.
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
