Aller au contenu principal
Garmin Nuvi 1390LMT Battery Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: étape 1, image 1 de 1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: étape 2, image 1 de 2 Garmin Nuvi 1390LMT Battery Replacement: étape 2, image 2 de 2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: étape 3, image 1 de 1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: étape 4, image 1 de 2 Garmin Nuvi 1390LMT Battery Replacement: étape 4, image 2 de 2
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: étape 5, image 1 de 1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: étape 6, image 1 de 2 Garmin Nuvi 1390LMT Battery Replacement: étape 6, image 2 de 2
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: étape 7, image 1 de 1
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: étape 8, image 1 de 2 Garmin Nuvi 1390LMT Battery Replacement: étape 8, image 2 de 2
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
Ligne d'arrivée
3 autres ont terminé cette réparation.
Trey Ulsh
Membre depuis le 10/22/15
537 Réputation
3 tutoriels rédigés
Équipe
Montana Tech, Team 10-4, Shirk Fall 2015 Membre de l'équipe Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
5 membres
3 tutoriels rédigés
Un commentaire
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 33
Total : 3,730
