Aller au contenu principal
Garmin Nuvi 1490T Display Screen Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 1490T Display Screen Replacement, Front Frame Panel: étape 1, image 1 de 1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Display Screen Replacement: étape 2, image 1 de 1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Display Screen Replacement: étape 3, image 1 de 2 Garmin Nuvi 1490T Display Screen Replacement: étape 3, image 2 de 2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: étape 4, image 1 de 3 Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: étape 4, image 2 de 3 Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: étape 4, image 3 de 3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Display Screen Replacement: étape 5, image 1 de 3 Garmin Nuvi 1490T Display Screen Replacement: étape 5, image 2 de 3 Garmin Nuvi 1490T Display Screen Replacement: étape 5, image 3 de 3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Display Screen Replacement, Display Screen: étape 6, image 1 de 3 Garmin Nuvi 1490T Display Screen Replacement, Display Screen: étape 6, image 2 de 3 Garmin Nuvi 1490T Display Screen Replacement, Display Screen: étape 6, image 3 de 3
    • Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
  7. Garmin Nuvi 1490T Display Screen Replacement: étape 7, image 1 de 2 Garmin Nuvi 1490T Display Screen Replacement: étape 7, image 2 de 2
    • Remove the piece of tape that is covering the connecting point of the motherboard and display.
  8. Garmin Nuvi 1490T Display Screen Replacement: étape 8, image 1 de 3 Garmin Nuvi 1490T Display Screen Replacement: étape 8, image 2 de 3 Garmin Nuvi 1490T Display Screen Replacement: étape 8, image 3 de 3
    • Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
    • Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
    • Gently disconnect the display by pulling upward. Set display aside.
    • If the display screen does not disconnect easily, make sure the ZIF connector is no longer holding it in place.
5 autres ont terminé cette réparation.
Ricardo Solis
Membre depuis le 01/20/16
1 037 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 15-2, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 membres
6 tutoriels rédigés
Un commentaire
Awesome!! Thank you for putting this out there. Helped me save buying a new gps when the screen on my got damaged.
George Gearing - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 2,642
