Aller au contenu principal
Garmin Nuvi 200 Speaker Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: étape 1, image 1 de 2 Garmin Nuvi 200 Speaker Replacement, Rear Casing: étape 1, image 2 de 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Speaker Replacement: étape 2, image 1 de 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Speaker Replacement: étape 3, image 1 de 2 Garmin Nuvi 200 Speaker Replacement: étape 3, image 2 de 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Speaker Replacement, Speaker: étape 4, image 1 de 1
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
  5. Garmin Nuvi 200 Speaker Replacement: étape 5, image 1 de 1
    • Pull the cable out to detach the speaker from the logic board.
  6. Garmin Nuvi 200 Speaker Replacement: étape 6, image 1 de 3 Garmin Nuvi 200 Speaker Replacement: étape 6, image 2 de 3 Garmin Nuvi 200 Speaker Replacement: étape 6, image 3 de 3
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
3 autres ont terminé cette réparation.
Anjelica
Membre depuis le 04/11/10
564 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 25-90, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 membres
9 tutoriels rédigés
2 commentaires
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - Réponse
Where can you buy replacement speakers for the Garmin units?
Brat Fry - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 7,076
