Aller au contenu principal
Garmin Nuvi 200w Screen Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 200w Screen Replacement, Rear Cover: étape 1, image 1 de 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: étape 1, image 2 de 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: étape 1, image 3 de 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Screen Replacement: étape 2, image 1 de 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Screen Replacement: étape 3, image 1 de 3 Garmin Nuvi 200w Screen Replacement: étape 3, image 2 de 3 Garmin Nuvi 200w Screen Replacement: étape 3, image 3 de 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Screen Replacement: étape 4, image 1 de 2 Garmin Nuvi 200w Screen Replacement: étape 4, image 2 de 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Screen Replacement, Display Assembly: étape 5, image 1 de 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: étape 5, image 2 de 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: étape 5, image 3 de 3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
  6. Garmin Nuvi 200w Screen Replacement, Screen: étape 6, image 1 de 3 Garmin Nuvi 200w Screen Replacement, Screen: étape 6, image 2 de 3 Garmin Nuvi 200w Screen Replacement, Screen: étape 6, image 3 de 3
    • Using your plastic opening tool, apply pressure on the top right of the screen in order to remove some of the tabs.
    • Work the plastic opening tool around the whole screen to remove the tabs from the screen.
    • Carefully separate the screen from the front cover.
Matthew Eires
Membre depuis le 03/08/17
319 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S5-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 344
