Introduction
The mother board assembly is simple to replace and only takes 10-15 minutes to open the device and access the logic board. This guide requires a prying tool, the Torx 4 screwdriver, and the soldering kit.
Ce dont vous avez besoin
Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
Remove the two 1.0mm 04# Torx screws from the mother board assembly
One screw can be found directly to the right of the battery and one screw can be found behind the orange band.
Hold the GPS with a free hand to ensure stability.
Place the screen portion of the GPS face down.
Remove the mother board from the plastic back panel.
Disconnect the battery with tweezers by gripping the white socket displayed in the photo. Wiggle the white socket out of the mother board.
Use a soldering tool to de-solder the connection to the motherboard. Refer to the iFixit Soldering guide to see how
