Aller au contenu principal
Introduction
The mother board assembly is simple to replace and only takes 10-15 minutes to open the device and access the logic board. This guide requires a prying tool, the Torx 4 screwdriver, and the soldering kit.
  1. Remove the four 2.5mm screws  from the back assembly with a Torx #04 Screwdriver.
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel. To properly remove the back cover assembly pry open both the back and sides of the assembly.
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Open the device carefully being wary of the orange band that is going from the screen to the motherboard. Remove the orange band by carefully lifting the lip that connects it to the motherboard. Remove the orange band by carefully lifting the lip that connects it to the motherboard.
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Remove the two 1.0mm 04# Torx screws from the mother board assembly
    • Remove the two 1.0mm 04# Torx screws from the mother board assembly
    • One screw can be found directly to the right of the battery and one screw can be found behind the orange band.
    • Hold the GPS with a free hand to ensure stability.
  5. Place the screen portion of the GPS face down. Remove the mother board from the plastic back panel.
    • Place the screen portion of the GPS face down.
    • Remove the mother board from the plastic back panel.
    • Disconnect the battery with tweezers by gripping the white socket displayed in the photo. Wiggle the white socket out of the mother board.
  6. Use a soldering tool to de-solder the connection to the motherboard. Refer to the iFixit Soldering guide to see how
    • Use a soldering tool to de-solder the connection to the motherboard. Refer to the iFixit Soldering guide to see how
Nathaniel Williams
Membre depuis le 19/09/2016
264 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 2-3, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 417
