Aller au contenu principal
Garmin Nuvi 2455LMT Touch Screen Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 2455LMT Touch Screen Replacement, Back Panel Assembly: étape 1, image 1 de 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Touch Screen Replacement: étape 2, image 1 de 2 Garmin Nuvi 2455LMT Touch Screen Replacement: étape 2, image 2 de 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Touch Screen Replacement: étape 3, image 1 de 3 Garmin Nuvi 2455LMT Touch Screen Replacement: étape 3, image 2 de 3 Garmin Nuvi 2455LMT Touch Screen Replacement: étape 3, image 3 de 3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: étape 4, image 1 de 2 Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: étape 4, image 2 de 2
    • Locate the edge of the screen that fits into the plastic case
    • To separate the connector, gently push the tip of a spudger under the clip.
    • Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
  5. Garmin Nuvi 2455LMT Touch Screen Replacement: étape 5, image 1 de 1
    • Use the plastic opening tool to wedge between the plastic cover and screen.
    • Using your hands, gently push the front of the screen towards you to push the screen out of the casing.
Torrance Williams
Membre depuis le 09/15/16
229 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 2-3, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 597
