Aller au contenu principal
Garmin Nuvi 2557LMT Speaker Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 2557LMT Speaker Replacement, Garmin Nuvi 2557LMT Disassembly: étape 1, image 1 de 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Speaker Replacement: étape 2, image 1 de 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Speaker Replacement: étape 3, image 1 de 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Speaker Replacement: étape 4, image 1 de 2 Garmin Nuvi 2557LMT Speaker Replacement: étape 4, image 2 de 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Speaker Replacement, Speaker: étape 5, image 1 de 1
    • Using a plastic opening tool, wedge the speaker from the device.
    • Don't pull it out of the device too far. It is still connected to the motherboard wire.
  6. Garmin Nuvi 2557LMT Speaker Replacement: étape 6, image 1 de 1
    • Using a soldering iron, desolder the wire connection between the speaker and the device.
Monica Webber
Membre depuis le 03/31/16
231 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 194
