Aller au contenu principal
Garmin Nuvi 2589LMT Display Assembly Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 2589LMT Display Assembly Replacement, Back Panel Assembly: étape 1, image 1 de 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Display Assembly Replacement: étape 2, image 1 de 2 Garmin Nuvi 2589LMT Display Assembly Replacement: étape 2, image 2 de 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Display Assembly Replacement, Display Assembly: étape 3, image 1 de 1
    • Using the tweezers, gently pull the ribbon wiring near where it connects to the motherboard to disconnect the ribbon wiring and the display screen from the motherboard.
    • Remove the screen from the device.
Adam Ferraro
Membre depuis le 10/04/16
920 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Nance Fall 2016 Membre de l'équipe USF Tampa, Team 1-2, Nance Fall 2016
USFT-NANCE-F16S1G2
4 membres
8 tutoriels rédigés
2 commentaires
Could you please advise where can I find replacement screen for this device
joyarvind - Réponse
I got the ribbon off. There is a plastic piece that flops around that the ribbon was adhered to. Will the replacement ribbon have some type of adhesive on it for installation? Thanks.
Marty Griffin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 12
Total : 2,412
