Aller au contenu principal
Garmin Nuvi 2589LMT Speaker Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 2589LMT Speaker Replacement, Back Panel Assembly: étape 1, image 1 de 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Speaker Replacement: étape 2, image 1 de 2 Garmin Nuvi 2589LMT Speaker Replacement: étape 2, image 2 de 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Speaker Replacement, Speaker: étape 3, image 1 de 1
    • Wedge the speaker from the device, using the small plastic opening tool.
    • The speaker is held in place by adhesive tape on the outer rim. Because the speaker is still connected to the motherboard, pry the speaker away from the device gently.
  4. Garmin Nuvi 2589LMT Speaker Replacement: étape 4, image 1 de 1
    • Using tweezers, remove the tape covering the speaker connection to the motherboard.
  5. Garmin Nuvi 2589LMT Speaker Replacement: étape 5, image 1 de 1
    • Using a soldering iron, desolder the wire connection at the soldering points between the speaker and the motherboard to remove.
    • Learn more about soldering and desoldering connections here.
Adam Ferraro
Membre depuis le 10/04/16
920 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Nance Fall 2016 Membre de l'équipe USF Tampa, Team 1-2, Nance Fall 2016
USFT-NANCE-F16S1G2
4 membres
8 tutoriels rédigés
Un commentaire
What size was the speaker in inches or mm? How many ohms was it? Where did you find the replacement?
george.terbush - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 8
Total : 354
