Introduction
This guide will walk you through the process of replacing a faulty or broken LCD screen in your Garmin Nuvi 2597LMT. You may need this guide to replace the LCD if it is cracked, not showing anything at all, not responding to touch, or pixelated. Make sure you are very careful when working with your device; you don't want to break any of the fragile components inside or rip the ribbon cable connecting the two halves.
Ce dont vous avez besoin
Turn your device over so the back is revealed and you can see the screws in the four corners.
Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
3 autres ont terminé cette réparation.
