Aller au contenu principal
Garmin Nuvi 2689LMT Screen Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 2689LMT Screen Replacement, Screen: étape 1, image 1 de 1
    • Remove the stand by depressing the tab and rocking the round interface back away from the tab, pulling it away from the Garmin unit.
  2. Garmin Nuvi 2689LMT Screen Replacement: étape 2, image 1 de 1
    • Remove the four 4mm hex screws from the four corners of the unit using a T5 bit.
  3. Garmin Nuvi 2689LMT Screen Replacement: étape 3, image 1 de 1
    • Place the unit screen-side down flat, with the bottom facing you. There are two seams; the one on top is artificial.
    • This is the real seam—open it with a plastic opening tool in step 4.
  4. Garmin Nuvi 2689LMT Screen Replacement: étape 4, image 1 de 1
    • Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the tool into the unit until you feel a click.
    • Repeat this all the way around the seam.
  5. Garmin Nuvi 2689LMT Screen Replacement: étape 5, image 1 de 3 Garmin Nuvi 2689LMT Screen Replacement: étape 5, image 2 de 3 Garmin Nuvi 2689LMT Screen Replacement: étape 5, image 3 de 3
    • Do not attempt to separate the unit until all the tabs have been separated. Once the seam is completely separated, you can lift the back away from the screen easily.
  6. Garmin Nuvi 2689LMT Screen Replacement: étape 6, image 1 de 1
    • Retrieve a new screen and connect the flat-gold wire to the socket from where you removed the old screen.
2 autres ont terminé cette réparation.
Spencer
Membre depuis le 09/26/16
273 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 16-5, Eyestone Fall 2016 Membre de l'équipe USF Tampa, Team 16-5, Eyestone Fall 2016
USFT-EYESTONE-F16S16G5
3 membres
5 tutoriels rédigés
2 commentaires
Were can I order a 6 inch screen for a Garmin Nuvi 2689 LMT
James Fraley - Réponse
The screws will not come out. I have the screwdriver that was sent with replacement screen. Help!!
debbie_reeves - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 12
Total : 1,239
